First Aussie ride :(
Discussion in 'Main Forum' started by _Yappa_, Nov 19, 2012.
  1. megawatt
    Adjustable dogbones are better than fixed, you can adjust them to exactly what you need and do it without dismantling the suspension, once you've fitted them. Once back end feels right, lower front end by 5 to 10mm. Could also be a shock problem?
  2. lammyR6
    lammyR6 Moderator Staff Member Moderator +
    It definitely sounds like its the set up of your bike as opposed to wrong bike or lack of riding confidence. Last summer I began to think that I had totally lost my bottle on the road, couldn't corner anymore etc etc. I couldn't really explain the feeling it gave mid corner either but knew it was wrong. Only when a couple of friends actually rode my bike and basically said "holy c**p how are you riding that?!" that I knew it wasn't just me lol. Turns out the rear linkage bearings were seized so rear shock was not behaving as it should and it did completely muck up the handling.
    Is there anyone else who can have a look at the bike? Sounds like the adjustments have not been done correctly and have completely thrown off the handling. In the meantime, can you have a ride on your hubby's? Just to get your confidence back until yours is sorted?
    Hope you get it all sorted! xx
    Amancalledrob and megawatt like this.
  3. Skortchio
    Lots of misconception flying about here.
    Firstly - if you lower the rear of your bike, to maintain correct weight bias and steering geometry you MUST adjust the front to compensate. Fact!
    But, as Megawatt says depending on your bikes stock trail this can be omitted until you have the found the most suitable height.
    Secondly - don't use a hammer where you need a screwdriver. A metal fabricator may be able to make your lowering links but he may not understand suspension geometry, hell most mechanics don't.
    Your handlebars impinging on the fork tops can be overcome by using heigher risers (the bit that bolts onto the yoke) but that said the relative amount you would have lowered the rear by to need that much front adjustment would likely be unridable.
    Third - You need to approach this logically to get your confidence in your machine. Do the basic checks, set the suspension to standard height and adjustment all round, check your tyres for correct pressure, cables for slack, bearing play etc.
    Then ride it.
    Being able to touch the floor is nothing to do with how a bike corners, it only matters when you stop. If the bike isn't tracking in a bend correctly that's a geometry / suspension problem, the feeling that the back is trying to take a different line midway through the bend is down to rear compression - likely as a result of the poor geometry. Uneven feel in the corner is mostly front preload.
    Start from a known position and adjust from there.
    Forth - You don't need fancy adjustable suspension links, you only need to get your boot on the floor and you know already how low that is. What is needed is the suspension being brought back into alignment, that will stop the vague front end and the poor corner tracking.
    Most basic approach is thus:
    Fit original dogbones and set suspension to stock settings.
    Measure height at 2 known points, 1 front 1 rear (bottom of fairing is fine for this).
    Change dog bones and measure new rear height.
    Adjust the fork protrusion to give a relative change - As MW says, this will likely only be a few mm at most.
    Set your static sag - if nothing else almost all suspension comes with preload adjustment.
    Ride bike.
    Smiles.
    Lastly - Don't bother hacking up your stock clutch lever, buy an adjustable one if yours isn't already. If it is than a motorcross easy pull level will be perfect for you, you can adjust the fulcrum to let you pull with 1 finger easily and the level position is totally adjust able.
    :cool:
  4. BlackHornet
    Skortchio is pretty close :thumbsup:
    but i have a much easier way,
    Step one find and ozzy skortchio, will most likely still have pony tail and beard / mo but will drive a ute not a mini. can be spotted by having mini pistons instead of corks hanging from his hat.
    step two get him to do it :thumbsup:
    step three ride :D :MC:
    _Yappa_, alexs, Roadwart and 2 others like this.
  5. Les
    He might even come thru' your hosp needing an oil change.
    _Yappa_ likes this.
  6. _Yappa_
    _Yappa_ Official SECB representative down under. +
    Well to update to this....Went for a 350km ride today with hubby (ER6N) and father-in-law (Hornet).
    I'VE FOUND MY GROOVE (aka confidence) !!!!!!!!!!!!!!!!!!
    Ripped it around 3 mountain ranges in the wet and wasn't sitting in second gear. Even managed to keep up with hubby. Bout bloody time I say! Accident was in April and only feeling good on bike now (January)!!
    So happy I've cracked a bottle of bubbly for myself :hgiggle:
    hoppielimp, Fergy, Panel Man and 7 others like this.
  7. kitten_art
    kitten_art Race Rep +
    :disco:
    _Yappa_ likes this.
  8. Amancalledrob
    Amancalledrob Street Fighter +
    Amazing news :)
    _Yappa_ likes this.
  9. Roadwart
    Glad you have found your biking mojo again :thumbsup:
    _Yappa_ likes this.
  10. lammyR6
    Yaaaaay!!! I know how nice a feeling that is. Enjoy the bubbly! xxx
    _Yappa_ likes this.
  11. BlackHornet
    :Whoo3::ron1::cool2:
    gotta love having your mojo back :D
    _Yappa_ likes this.
  12. lost
    lost Samsung leaflet fetishist +
    well done you:respekt:and you could always send a few%) this way
    _Yappa_ likes this.
