08/01/12 sunday,blue and white cafe
Discussion in 'General Rideouts' started by sexyminx, Jan 7, 2012.
  1. sexyminx
    sexyminx British Superbike +
    http://g.co/maps/626nb
    hi ya guys and gals.me and dave are going to blue and white cafe sunday and all are welcome.think ive sorted the map out right.was thinking of meeting up at tesco in hawkhurst at 10.15 to leave at 10.30 ish.
  2. Gazza1
    Gazza1 Guest
    sounds good to me :rubhands:
  3. lammyR6
    lammyR6 Moderator Staff Member Moderator +
    Sorry only just saw this otherwise saw this! Mind you, tis a bit chilly out there and I need to do some work on the bike so guess I will stay home today. Have fun. :)
  4. Finchy
    Finchy Guest
    Hi Lammy - did you sort that 'lumpiness' in your engine? If so, what was it? Airbox?
  5. BlackHornet
    been running just a little late today :D will be jumping on a bike at 11.45 ish and then deciding where the hell i'm going to head :rolleyes: might try and find either you guys or the biggin hill group, or just blat from c afe to cafe instead :rolleyes: :thumbsup:
  6. lammyR6
    Problem still not sorted. Airbox and spark plugs have been changed and its still bogging down at 8,000 rpm. Reckon they fuelling isn't right? Think I'll have to take it back to the guy who balanced the carbs in the first place and see if he can sort it seeing as it only got worse after he'd had it!
  7. Ducky
    Lammy, does it rev freely in neutral and only bog down when under load; can you ride through the boggy patch?
    Does the R6 have ram air on it; I would assume so...tis worth checking the piping around the airbox/carbs, as anything disconnected will kill performance under load and cause bogging down etc. :thumbsup:
  8. JimG
    JimG British Superbike +
    Sorry - would have liked to have come, but was out yesterday and was given my 'homework' to do today.
  9. DAVE B
    DAVE B British Superbike +
    good run out bit cold good food.maybe we can all do the run soon :thumbsup:
  10. Finchy
    Finchy Guest
    Ducky - no, her bike is lumpy even on idle. Lammy was concerned that it doesn't clear and affects performance under load. It could also possibly be a partially blocked fuel filter too. However, getting the carbs re-balanced seems logical if the problem arose after the guy fiddled with it.
  11. lammyR6
    It seems to choke when you hit around 8,000 which is normally where the power kicks in again. It idles ok although the other day it revved to 4,000 while I was waiting at the lights and hadn't touched the throttle :eek:. However as Fergy pointed out at the time, maybe the bike was getting impatient and just wanted to go lol! Will see mechanic this week and try sort it out. Will also check fuel filter and if there is more air than should be getting in. Thanks for all your tips guys. Much appreciated!
  12. BlackHornet
    sorry i never caught you guys up today, i was running late so treated my self to a blast to rye 7 police cars and a speed trap :thumbsdown: then back home before heading to Leilas and from there to lewis and back, the roads were nice and empty tonight and the full moon gave enough light that it was possible to have some fun :D
  13. Panel Man
    Is the Exup valve working ok? I understand these things tend to gum up...
  14. Russell
    Where were they doing the speed trap?
  15. Skortchio
    Unbalanced carbs won't cause a loss of power par sé, only poor response / idle. A massive loss of power at 8k would indicate fueling itself or the ratio of fuel / air.
    It's almost impossible to balance carbs wrong, even doing it by ear. Rather than repeat myself (should of saved the message the first 6 times I told you), ditch the so called mechanic, get your money back and take it to someone with half a brain.
    Setting the fueling and checking the intake system works is an easy task as is balancing the carbs once you have a good mix.
    A RR session would be ideal though, I'm sure I saw an xmas special going on at HMR didn't I?
    Oh yeah, here it is!
    http://www.southeastcountiesbikers.co.uk/forum/threads/1378/
    Job done.
  16. Fergy
    Fergy Secret prototype +
    I am sure the revs increased when you bounced up and down on the bike whilst stationery too?????
  17. Skortchio
    2 possibilities;
    1) Whatever the cause it's alieviated by reduced load / movement of the bike.
    2) Good excuse to make Leila bounce up and down. I heard the best way to test is to reduce the rider weight as much as possible, bikini's are lighter than leathers, right? :rofl:
    Fergy likes this.
