What's pi$$ed me off today.........!!
Discussion in 'Main Forum' started by Ducky, Jul 14, 2011.
  1. BlackHornet
    It's the camping. Been twice on the R6 and twice it has hit the deck with no one on it. Must be some kind of reaction. Lol
    Skortchio likes this.
  2. Stars and Stripes
    Stars and Stripes Secret prototype + Site Supporter
    I suggest hotels next time ;)
  3. BlackHornet
    It turns out that dropping the bike has killed it. Not only did I do some cosmetic damage but knackered the engine hence the issues with it. So now i have to get my insurance company to sort the bike out. Trying to work out how to get me and my luggage home is the next thing to do. :-(.
  4. Skortchio
    Daymn, really? What the hell did you drop it off?
    What was the diagnosis? Engines are pretty, well, tightly fitted (normally). It's not exactly easy to dislodge an internal part - they wouldn't work if you could. :confused:
    Lucky I've got lots of garage space these days.
  5. lost
    lost Samsung leaflet fetishist +
    oh shit thats a nightmare mate. did you take out breakdown insurance ?
  6. BlackHornet
    Just from a curb. Maybe didn't help jumping straight back on it. I am hoping it is just a piston ring. It's 80% down on compression in number one. But won't know until the bike is recovered.
    I am not sure all the extra weight it had on it helped. The tent alone is over 25 kilos plus a set of panniers and my very heavy roll bag. It nose dived pretty much straight down.
    I am fully comp and have no excess which is a good thing.
    _Yappa_ likes this.
  7. SteveeP
    SteveeP Sport Tourer +
    Bugga bugga bugga
  8. SteveeP
    Makes my day seem not so bad!
    Took Blade for MOT....they noticed a slight play in the rear wheel (sprocket to wheel). Removed wheel, then sprocket from wheel and about 1000 bit of metal fell out. Rear Sprocket Bearing totally demolished!
    Damn good job it held out on me as this could have been a little nasty.
    Thankfully, John Harris Motorcycles had a bearing in stock so we did it there and then.
  9. GuzziRob
    GuzziRob Race Rep +
    John's always helpful
  10. Panel Man
    I'm really sorry to hear of this but am struggling to understand how laying the machine down (onto Leila's helmet) can cause #1 cylinder to lose compression. Might the cylinder head have hit the ground and been cracked or dislodged? Was Leila's head inside the helmet at the time? (...and been cracked or dislodged too)?
    What other symptoms were there? Smoke? Vibration? Inability to rev? Overheating?
  11. BlackHornet
    Ah it didn't do the helmet damage until I lifted the bike back up. Onto her empty helmet :) it did start to lose power shortly after but I put that down to the high altitude and blamed the smoking on mixing oil into the carburettors when it went over.
    I may have been wrong :-(
  12. lammyR6
    lammyR6 Moderator Staff Member Moderator +
    If my head was in the helmet it might have knocked some sense into me but sadly, or not?, it was not the case lol
  13. dulux
    dulux Off Roader
    If the cylinder was 80% down on compression sounds like the piston rings have said goodnight, maybe when it went over it partialy hydraulic locked somehow and then the weakest part failed which was the rings, that would explain a lot of blue smoke from exhaust, unlikely if the cylinder had been damaged from an external force it would be game over instantly.
    I hope you get back safe and sound, afriad can't help much on the French side of things, but will help over here if I can.
  14. BlackHornet
    Thanks mate. I think it was just enough to start the process of it going wrong. But I am hoping once the bike is home it can be sorted. If not then the hornet will be used more. :)
  15. JimG
    JimG British Superbike +
    Surely by the time the bike gets home it should have healed itself as your bikes normally do :rolleyes:
    lost likes this.
  16. BlackHornet
    Funny you should say that. The rev counter had started to work again :) lol.
    Stars and Stripes, JimG and lost like this.
  17. dulux
    dulux Off Roader
    Everything can be fixed, within reason, just might need a lot of tea along the way!
  18. lost
    tea more like vodka and duct tape :D
    id be more worried where shatterd plug bits went
  19. Roadwart
    Or it was already weakened & the fall was enough for it to snap completely.
  20. BlackHornet
    Could have been that but I had a full service done before the trip and boy was it running well. Scared myself on it a few times :)
