Not warped discs; what could it be??
Discussion in 'Mechanical' started by ro06k5, Aug 22, 2011.
  1. ro06k5
    ro06k5 Sport Tourer +
    Maybe the weekend; its not had a proper run yet. Depends how many hedges I have to cut..
  2. megawatt
    Gimme a shout, finish nights Sunday and off until next Friday?
  3. ro06k5
    It's always the simple things innit???
    Wasn't the forks, wasn't the wheel, wasn't the discs.....
    It's the bloody brake pads rattling on the brake pins :bhead:
  4. Skortchio
    That's drag from something not being lined up properly. Most likely a slightly sticky piston or air lock behind one, you pull the lever and one doesn't move as much as the other allowing the pad to shudder instead of being pressed firmly against the disc. By the sound of it.
    When you pull the lever the pads should be pressed firmly against the disc or you won't be braking, rattling means they're not and is bad.
  5. Carnage
    Carnage Race Rep +
    Just for the record if you have floating discs check the bobbins are clean and free .....i.e the disc is still floating
    On the gsx1400 its a common problem for the disc to become static due to road grime on the bobbins ...quick solve is.....
    put a nut and bolt through the bobbin and attach a drill to the bolt ....spray brake cleaner onto the bobbin and spin it at a reasonable speed ( you dont wanna make it glow :)) and that should clear all the crud and see your disc floating again.
